Gifting problem after upgrade lv8
Post by SannSunn on Thu Jan 30, 2014 10:37 pm
Another problem appeared since the upgrade with level 8.
I can't gift gifts from the neighbor screens anymore, it only works from the gift screen from which you have to select a neighbor, with the chance you accidentally select multiple neighbors, and you can't see how many other gifts you can give.
When you do want to gift from the neighbor screen you will get the gift screen after clicking the present (like usual), then you have to select the neighbor again, and when you then select the gift for the final time it will be sent (or maybe you have to do one more time).
f** annoying!!
Anyone else with this problem?
_________________________________________________
Please skip my game with gifting, I left the game for a while. I might be back so please don't delete my game. Thanks for your help! (March 24th, 2016)
If you add me as a neighbor, please send me a PM so I know you're from the forum.
If you need me to send something in return (because I cant gift it anymore), please send me a PM.
To visit I have:
2 Planetarium - Training center - Astronaut academy - Mission Control Center lv3 - Launch Pad 1&2&3 - 6 Research Lab -  4 Rocket Park - 4 Space Travel Monument - 2 Alien Legacy
Check my posts at the weekly swapping thread (Cross platform) to see what I need most and what I can gift.
- In-game-name is for non-forum neighbors -
Thank you all for your help!
Alliance: SST4 (Izabelka81, CarlosfromNYC, R3d_F1v3, Drivefast99)
SannSunn
Level : 60 (312 stars)
Items I Can Gift : (All the usual flight items) Pax5 - Fuel20 - Shampoo - ATM - Single malt whiskey - Paint - Generator - Tour review - Projector - Rope block - Video wall - Laser level - Flight helmet - Eau de Toilette - Jet Engine - Stapler - Power source - Spaceship launch console - Make-up - Amperemeter - Laser cutter - Landing gear - Cooling chamber - Archivebox - Altimeter - Controller - Flatwork ironer - Crucible. Able to send in return (ONLY after PM): Lvl7: Mayor's portrait, Beverage cooler, Monitor - Lvl8: Podium, X-Ray scanner, Laser rangefinder - Lvl9: Postal drone, Turnstile, Infrared camera - Lvl10: Explosives Detector, Laminator, Drawing Board - MCC lvl3: Offset Gregorian Antenna - Repair base lvl6: Riveter - Reserve hangar lvl1: Wheel block, lvl2: Fluorescent Lamp, Lvl3: Machine Oil
Re: Gifting problem after upgrade lv8
Post by drivefast99 on Fri Jan 31, 2014 12:05 am
I had the same issue yesterday but today... so far.... it seems to be working correctly again.
It was definitely a challenge yesterday to send out gifts. I hope it's corrected.
Please PM me if you need something.  Please PM me if adding me as a friend - otherwise, I will not confirm.
Items I can gift in return:
Motion Sensor, 3D Printer, Patrol Drone, Parking Meter, Walkie Talkie, Vivaldi antenna, Riveter, Wheel Block, Loader, Document Detector, Paper Cutter, Protractor.
Launch Rules: If you see my launch, feel free to join and take any place.
drivefast99
Level : 70
Items I Can Gift : DF99: Fuel Catalyst, DND Sign, Imprinter, Chocolate Candies, Paint, Generator, Album, Landing Lamp, Dispatcher Console, Channel Bar, Fuel (20), Powerful Radio Transmitter, Spaceship Engine, Glass Display Case, Cognac, Fuel Supply, Aircraft Tire, Calculator, Fuel Additives, Insulation, Solar Cell, Additional Radar, White Gold Bracelet, Smoke Detector, Spare Wire, Hull Parts, Passenger Seat, Oscillating Beacon, Flight Catering, Cooling Chamber, Navigation Module, Archive Box, Fuel Hose, Altimeter, Spare Propeller, Deicer, Grinding Machine, Wireless Compass, Flatwork Ironer, Blanket, Attitude Indicator, Screw Press. df19: Fuel (3), Do Not Disturb Sign, ATM, Pearl Earrings, Cockpit Glass, Generator, Tour Review, Projector, Rope Block, Fuel (20) , Video Wall, Robot Tester, Glass Display Case, Eau De Toilette, Jet Engine, Wide Angle Binoculars, Power Source, Communication Antenna, White Gold Bracelet, Smoke Detector, Server Rack, Landing Gear, Defroster, Master Plan, Gyroscope, Controller, Arcade Machine, Flatwork Ironer, Calibration Module, Screw Press.
Post by drivefast99 on Sat Feb 01, 2014 10:40 am
Well, this is still a problem for me. Sometimes it works right - I click on a neighbor then click an item to send.
Other times, when I click the item to send, I get a friends list, click it, then get the items list again, click it, then get the friends list again, click it, then get the item again and it will FINALLY send Sad
Today, the 1st gift went fine, the next was insane.
drivefast99
Level : 70
Post by el_angelus on Sat Feb 01, 2014 4:31 pm
drivefast99 wrote:Well, this is still a problem for me.  Sometimes it works right - I click on a neighbor then click an item to send.
 Same problem here...another GI bug!
Items I can send
:)angelus              ---> check what can I send --->
el_angelus
Level : 71 (312 stars)
Items I Can Gift : :)angelus can send: Fuel catalyst, DND sign, bench, computer, whisky, cockpit glass, welder, album, landing lamp, projector, channel bar, passengers (10), powerful radio, assembly robot, anti theft gate, eau de toilette, fuel supply, jet engine, whiteboard, fuel additives, drill machine, comm. antenna, add'l radar, make up, smoke detector, spare wire, hull parts, landing gear, osc beacon, flight catering, cooling chamber, nav module, archive box, fuel hose, gyroscope, spare prop, deicer, grinding machine, hand dryer, explosive detector, wireless compass, washing machine, blanket, alt indicator, draw table, calibration modules, glazing machines, ear plugs and lollipops
http://airportcity.the-talk.net/u463
Post by eF on Fri Feb 07, 2014 1:19 am
Its not a bug its a feature Very Happy (Same here, its annoying)
My NEW friendcode is a1lgzk9 RE-ADD me (first remove my old acc, and add new one please, otherwise I will not receive any gift from you. Thank you
LAST UPDATE 12-DEC-2014 12:30
Items I can gift: Fuel (3), Passengers (5), Fuel Catalyst, Silver Sickle, Do Not Disturb Sign,Marking Machine, Goal Posts, ATM, Single-Malt Whiskey, Cockpit Glass, Welder, Album, Landing Lamp, Projector, Handling Line, Passengers(10), Powerful Radio Transmitter, Assembly Robot, Anti-Theft Gate, Eau De Toilette, Fuel Supply, Jet Engine, Whiteboard, Fuel Additives, Drill Machine, Solar Cell, Additional Radar, Makeup, Amperemeter, Spare Wire, Laser Cutter, Landing Gear, Oscillating Beacon, Flight Catering, Cooling Chamber, Navigation Module, Archive Box, Fuel Hose, Gyroscope, Spare Propeller, Deicer, Grinding Machine, Wireless Compass, Centrifuge, Blanket,Flatbed Scanner, Attitude Indicator
eF
Level : 50
Items I Can Gift : Items I can gift: Smart Glass, Holographic Display, Stabilized Binoculars, Wireless Compass, Centrifuge, Blanket, Passengers(5), Fuel(3),Fuel Catalyst,, Do Not Disturb Sign, Goal Posts, ATM, Single-Malt Whiskey, Cockpit Glass, Welder, Album, Landing Lamp, Projector, Handling Line, Passengers(10), Powerful Radio Transmitter, Assembly Robot, Anti-Theft Gate, Eau De Toilette, Fuel Supply, Jet Engine, Whiteboard, Fuel Additives, Drill Machine, Solar Cell, Additional Radar, Makeup, Amperemeter, Spare Wire, Laser Cutter, Landing Gear, Flight Catering, Oscillating Beacon, Cooling Chamber, Navigation Module, Archive Box, Fuel Hose, Gyroscope, Spare Propeller, Deicer, Grinding Machine
