Question About Hanger Types
Post by airbuscity on Fri Aug 15, 2014 2:35 am
We all know there are 5 different levels of Hanger and that from level 2 up each Hanger type can speed up maintenance of a particular category of plane on the runway (i.e. loading fual & passengers).
Can anyone clarify though whether you require one Hanger of a particular level for each one plane of the associated category to get the speed benefit, or whether having a single Hanger of that level allows you to speed up multiple planes in the associated category? For example, if I have 2 Jumbos then do I need to have 2 Level 5 Hangers to have them both loaded up at the faster speed or will a single level 5 Hanger give me the speed benefit on both Jumbos (even if the second one is housed in a level 1 Hanger)?
airbuscity
Level : 49
Items I Can Gift : Fuel Catalyst - All-Inclusive Bracelet - Air Conditioner - Pearl Earrings - Cockpit Glass - Welder - Travel Guide - Landing Lamp - Dispatcher Console - Sand Bag - Fuel 20 - Powerful Radio Transmitter - Video Wall - Textbook - Eau de Toilette - Fuel Supply - Jet Engine - Wide-angle Binoculars - Fuel Additives - Drill Machine - Communication Antenna - Additional Radar - Makeup - Shredder - Spare Wire - Hull Parts - Landing Gear - Oscillating Beacon - Flight Catering - Packaging Machine - Navigation Module - City Model - Fuel Hose - Gyroscope - Spare Propeller - Deicer - Yagi-Uda Antenna - Air Vent Filter - Monitor - Holographic Display - Wireless Compass - Dryer - Blanket - Altitude Indicator
Re: Question About Hanger Types
Post by drivefast99 on Fri Aug 15, 2014 3:22 am
I have 2 jumbos - one is in a level 5 hangar and one is in a level 1 hangar. The one in the level 5 hangar loads faster than the one in the level 1 hangar.
Not 100% sure but I read that even if you buy a level 5 hangar, you have to buy the jumbo specifically for it. Having the hangar won't speed up an existing plane in a lower hangar and the only way to move a plane from one hangar to another is to sell it and buy it again. Fairly expensive proposition for a little bit of speed.
I usually collect coins and passengers while my plane is loading up so I'm busy and the speed is not really a factor for me.
_________________________________________________
Please PM me if you need something.  Please PM me if adding me as a friend - otherwise, I will not confirm.
Items I can gift in return:
Motion Sensor, 3D Printer, Patrol Drone, Parking Meter, Walkie Talkie, Vivaldi antenna, Riveter, Wheel Block, Loader, Document Detector, Paper Cutter, Protractor.
Launch Rules: If you see my launch, feel free to join and take any place.
drivefast99
Level : 70
Items I Can Gift : DF99: Fuel Catalyst, DND Sign, Imprinter, Chocolate Candies, Paint, Generator, Album, Landing Lamp, Dispatcher Console, Channel Bar, Fuel (20), Powerful Radio Transmitter, Spaceship Engine, Glass Display Case, Cognac, Fuel Supply, Aircraft Tire, Calculator, Fuel Additives, Insulation, Solar Cell, Additional Radar, White Gold Bracelet, Smoke Detector, Spare Wire, Hull Parts, Passenger Seat, Oscillating Beacon, Flight Catering, Cooling Chamber, Navigation Module, Archive Box, Fuel Hose, Altimeter, Spare Propeller, Deicer, Grinding Machine, Wireless Compass, Flatwork Ironer, Blanket, Attitude Indicator, Screw Press. df19: Fuel (3), Do Not Disturb Sign, ATM, Pearl Earrings, Cockpit Glass, Generator, Tour Review, Projector, Rope Block, Fuel (20) , Video Wall, Robot Tester, Glass Display Case, Eau De Toilette, Jet Engine, Wide Angle Binoculars, Power Source, Communication Antenna, White Gold Bracelet, Smoke Detector, Server Rack, Landing Gear, Defroster, Master Plan, Gyroscope, Controller, Arcade Machine, Flatwork Ironer, Calibration Module, Screw Press.
Post by eatteveld on Fri Aug 15, 2014 3:40 am
I think you're right drivefast. I have a similar situation with 2 delta's, 1 in a level 1 hangar and 1 in a level 3 hangar. There is no way to move your planes between hangars other than what you said.
cheers
erik
eatteveld
Level : 50
Items I Can Gift : Fuel Catalyst, Shampoo, Bath towel, Robotic lawnmower, Goal Posts, Airco, Imprinter, Pearl earrings, Cockpit Glass, Welder, Generator, Great shots, Tour review, Landing Lamp, Radar, Disatcher Console, Handling Line, Rope Block, Fuel (20) Powerful radio Transmitter, Spaceship Engine, Robot tester, Security camera, Slide Rule, Cognac, Fuel Supply, Jet Engine, Calculator, Wide-Angle Binoculars, Fuel Additives, Drill Machine, Power Source, Spaceship Launch Console, Solar Cell, Additional radar, White Gold Bracelet, Perfume, Ergonomic Chair, Shredder, Spare Wire, Stamp, Hull Parts, Landing Gear, Oscilating Beacon, Flight catering, Packaging Machine, Defroster, Navigation Module, City Model, Master plan, Fuel Hose, Gyroscope, Altimeter, Spare Propeller, Deicer, Air vent Filter, Router, Demodulator, Wireless Compass, Centrifuge, Blanket.
Post by Bastoska on Fri Aug 15, 2014 3:15 pm
The hangar level is tied to the plane that was bought for it. You could have 9 level 5 hangars, and 1 level 1, and if you buy a Jumbo for the Level 1 it will load slow. I just avoid the whole issue and just buy level 5 hangars, much easier that way.
I am the original "SPACE PIRATE"!! Accept no substitutes.
Bastoska
Level : 55
Items I Can Gift : Fuel 3 Units, Passengers (5), Fuel Catalyst, Bath Towel, ATM, Single Malt Whiskey, Paint, Generator, Great Shots, Landing Lamp, Radar, Handling Line, Passengers (10), Powerful Radio Transmitter, Video Wall, Flight Helmet, Eau de Toilette, Fuel Supply, Aircraft Tire, Stapler, Fuel Additives, Drill Machine, Spaceship Launch Console, Additional Radar, Makeup, Cash Counter, Lining Plate, Passenger Seat, Oscillating Beacon, Flight Catering, Packaging Machine, Navigation Module, City Model, Fuel Hose, Altimeter, Spare Propeller, Deicer, Air Vent Filter, Wireless Compass, Dryer, Blanket, Attitude Indicator
Post by airbuscity on Sun Aug 17, 2014 7:32 pm
Thanks for the info folks - having the hanger level tied to the plane attached to that particular hanger probably makes the most sense in terms of GI's way of doing things.
Some things about my own airport set-up still don't make sense to me though. For some time, I've had 2 Deltas in blue hangers and a Powerful Delta in a red hanger. The Powerful Delta definitely loads faster then the regular Deltas, but the weird thing is one of my regular Deltas loads faster than the other scratch Question Question
And yes . . . not being able to move your planes between hangers, even when you have a completely empty hanger, is another very frustrating GI "game feature"   Rolling Eyes
cheers
abc
airbuscity
Level : 49
Post by Canterbury on Fri Aug 22, 2014 6:59 am
Brief history would be any plane could be bought and put into any hanger, this was changed so that only the plane of the same lvl or lower as the hanger could be stored. This must have been removed....
I have also noticed that clicking on a certain hanger will not guarantee the plane will leave that hanger if you have more than 1 of those planes...
So for more peace of mind I've simply moved and arranged the hangers so that the same plane type are grouped together .... especially handy when selling planes to change type for missions.
drivefast99 wrote: Not 100% sure but I read that even if you buy a level 5 hangar, you have to buy the jumbo specifically for it
Unless changed in the previous update this isn't the case as I've recently put a Turboprop into a lvl5 hanger....
Regards Canterbury- GMT+12
NZL(a7hymau)
Giftable lvl9 items Turnstile, 3d Printer
Giftable lvl8 items Fingerprint Reader
Requests
Repair Items
Fuel 20
Please PM me if you send a neighbor request so I know who's who; otherwise it will be ignored and eventually deleted!
Canterbury
Level : 50, 232
Items I Can Gift : NZL:, Fuel Catalyst, dnd, Bench, ATM, Whiskey, Cockpit Glass, Welder, Album, Landing Lamp, Copy Machine, Channel Bar, Passengers (10), P R Trans, Assembly Robot, Guestbook, Cognac, Fuel Supply, Jet Engine, Binocluars, Fuel Additves, Drill Machine, Optical System, Add Radar, w/G Bracelet, Cash Counter, Spare Wire, Lining Plate, Landing Gear, Osc Beacon,Flight Catering, Packaging Machine, Nav Module, City Model, Fuel Hose, Gyroscope, Spare Propeller, Deicer, Air Vent Filter, Turnstile, Fingerprint Reader, 3d printer, Wireless Compass, Washing Machine, Blanket, Altitude Indicator
