Repair Base upgrading question
Post by Glad2BMe on Thu May 03, 2012 6:14 am
I visit airportcity.the-talk.net and android airport city forums daily.
I am at level 22: stars 29 132/360? 172/166? ( the last 2, I don't know what they mean )
I have 62104 coins and $5
1 Repair base
1 Turboprop
3 Jets
1 Delta
4 hangers
I need to upgrade the repair base & have enough coins to do so.
I don't have enough land or enough cash to buy land yet. I will need to sell the current repair base to upgrade. It does not have a little green arrow about it, like the tower, city-hall or Terminal, so questions arrise.
Questions before I upgrade my repair base level 3 to level 4..
Do I Sell current repair base?
Will I be able to repair my other planes, while replacing or maybe under construction?
I have seen a yes on a forum or the pop ups, but how?
When I buy level 4 repair base, will I need certain items to be completely upgrade it?
(will it be under construction)?
If so how long is the construction?
How much would it cost to speed up the constructions?
This is where I am at. stuck. Rolling Eyes
sold 1 powerful propeller-driven.
Upgraded to a Delta.
Delta flew one flight, and needs repaired.
Only flight request are to Egypt, Goa, San Francisco, not unless I fly with the Delta.
I have no request to fly anywhere with my Jet planes, level 11-20 flights.
I fly randomly as per items the cities drop.
May need to buy the Power-Propeller again to fly to Egypt, not sure.
Glad2BMe
Level : 35 - 99 stars
Items I Can Gift : Items available to share: Fuel (3 units),5 Passengers, Air Conditioner, Computer, Cockpit Glass, Paint, Welder, Generator, Landing Lamp, Radar, Copy Machine, Projector,Dispatcher Console, Passengers (10), Fuel (20 units), Powerful Radio Transmitter, Flight Helmet, Flight Goggles, Slide Rule, Textbook, Guestbook, fuel Supply, Jet Engine, Aircraft Tire, Stapler, Weather Display, Wide-angle Binoculars, Whiteboard, Calculator, Fuel Additives, Power Source, Drill Machine, Insulation, Addition Radar, Ampermeter, Shredder, Cash Counter, Smoke Detector, Ergonomic Chair, Spare Wire, Laser Cutter, Hull Parts, Lining Plate, Server Rack, Stamp, Landing Gear, Passenger Seat, Oscillating Beacon, Flight Catering, Packing Machine, Cooling Chamber, Navigation Module, Archive Box, City Model, Master Plan, Transmitter, Fuel Hose,gyroscope, Altimeter, Spare Propeller, Deicer, TV
Re: Repair Base upgrading question
Post by Bertus on Thu May 03, 2012 8:16 am
I'm not that far in the game, but I can answer the following:
First: current population / maximum population.
Second: current energy usage / maximum energy usage. It seems you've sold an electricity building, since your current usage exceeds the maximum. I think you need to fix that before you can build any other buildings.
Bertus
Level : 30
Post by SR71 on Thu May 03, 2012 10:08 am
Glad2BMe wrote:I will need to sell the current repair base to upgrade. It does not have a little green arrow about it
You don't need to sell it. Although it doesn't have a green arrow, it will upgrade in-place like the Terminal or Control Tower etc.
No, see above.
Yes, you can continue to use your repair base while it is being upgraded (but only after it is constructed - it requires items to complete)
Not sure I understand this question.
Yes. See the third post of this thread for requirements.
Sorry, can't recall the answer to these ones, though in my opinion there are better things to spend your airport cash on instead of speeding up construction.
_________________________________________________
My Items Needed list is HERE. Any help would be much appreciated! Smile
I send out items DAILY, but it helps if you keep your Items Needed section of your Profile up-to-date, so I know what to send you!
SR71
Level : 35
Post by kos on Thu May 03, 2012 10:27 am
As to how to upgrade the Repair Base and how long the construction takes:
Go to the Store (shopping cart button, bottom left),
then to the airport buildings section (control tower button),
then find the Repair Base in there and tap it once to select it, the time it takes to construct will be shown at the bottom, you can then tap the buy button to start the upgrade construction process.
kos
Level : 35
Post by Glad2BMe on Thu May 03, 2012 6:51 pm
Thank you for your help.
I am grateful and thankful this forum is up and running.
I watch it get better everyday.
Whenever I get any missing info...I will certainly pass it on.
Razz
Glad2BMe
