Upgrade of hangars?
Upgrade of hangars?
Post by mekgmg on Fri May 11, 2012 10:23 pm
Can hangars be upgraded without it being sold first and then bying a new one? This requires selling the plane as well, as the hangar can only be sold when empty.
mekgmg
Level : 35 ( 101 stars)
Items I Can Gift : Gift available: Dnd sign, Fuel (3), , Air Conditoner, Cockpit Glass, Welder, Landing Lamp, Copy Machine, Passengers (10), Flight Goggles, Fuel Supply, Jet Engine, Stapler, Fuel Aditives, Power Source, Additional Radar, Shredder, Spare Wire, Hull Parts, Landing Gear, Oscillating Beacon, Flight Catering, Packaging Machine, Navigation module, Master plan, Fuel hose, Gyroscope, Spare propeller, Deicer, Air filter
Re: Upgrade of hangars?
Post by Dusss on Fri May 11, 2012 10:27 pm
Unfortunately you have to sell the hangar and plane if you want to replace the hangar.
Dusss
Level : 35
Post by tamildv on Sat May 12, 2012 7:34 pm
Do we have to upgrade the hanger, the game appears to let me have any plane in the level 2 hanger? what is the advantage of having a higher level hanger? (it says speeds up maintenance of plans on the runway)
Sorry if this is obvious, but I have clearly missed it.
thanks,
tamildv
Level : 40 (276 stars), 9 Hearts
http://airportcity.the-talk.net/u50
Post by SR71 on Sat May 12, 2012 8:34 pm
You can house any type of plane within any level hangar, so if you can avoid it, don't sell your lower-level hangars.
The advantage of having higher level hangars is that they will let you refuel/load your planes (and guest planes) faster. For example, a Level 2 hangar will let you refuel and load your propeller planes faster, so you can get them up and away faster.
_________________________________________________
My Items Needed list is HERE. Any help would be much appreciated! Smile
I send out items DAILY, but it helps if you keep your Items Needed section of your Profile up-to-date, so I know what to send you!
SR71
Level : 35
Post by tamildv on Mon May 14, 2012 5:01 am
thanks SR71, that makes more sense.
and many thanks for the hull parts, it has been a great help just one more to go.
tamildv
